1997 Chevy Cavalier clutch
1997 CHEVROLET CAVALIER
103,100 MILES • 6 CYL • FWD • MANUAL
MARKP61
The clutch works fine but when you put it into gear it shifts hard and then it jumps into gear really quick then won't release. What is wrong? what do i do?
Feb 24, 2009 at 5:20 PM
MMPRINCE4000
  • 8,548 POSTS
Most likely the clutch hydraulic system (slave and MC) is at fault. Make sure clutch MC is full, if problem persists change slave, and on most Cav's it is in the input shaft of trans, so trans will have to be removed.
Feb 25, 2009 at 5:47 AM
