1996 Chevy Cavalier Wont go into 2nd.
1996 CHEVROLET CAVALIER
95,000 MILES • 4 CYL • FWD • MANUAL
PHADEM
I just replaced the clutch, pressure plates, master cylindar, and the slave cylindar. It has been about 4 months and now i cant go into second or when i can it sometimes slips.
Oct 22, 2008 at 1:12 PM
MMPRINCE4000
  • 8,548 POSTS
Bleed the slave cylinder and look for any leaks in the clutch hydraulic system.
After bleeding, have someone push in clutch and observe slave rod, should move freely and about 1".
If not then clutch MC may be bad or a leak in system
Also make sure the motor mounts are good, no excessive movement of engine.
Oct 23, 2008 at 7:09 AM
