1996 Chevy Cavalier Water Pump Bearing
1996 CHEVROLET CAVALIER
JCURTS75
  • 12 POSTS
Noises problem
1996 Chevy Cavalier 4 cyl Automatic 135000 miles
I have a bad water pump that I put sealant into that has minimized the leak pretty well. Now a month or 2 later, I'm getting a grinding and high pitch noise (similar to what you would hear if your window was cracked just a little). Researcing online I'm 95% sure it is the water pump bearing.
Can I keep driving if I continue to add antifreeze? Or will the bearing eventually just not work anymore? If it stops working, the car overheats?
Aug 20, 2010 at 1:11 PM
WRENCHTECH
  • 20,761 POSTS
If you keep abusing your car like that your going to end up buying a motor for it. NEVER but sealer in a cooling system to fix a leak. All you accomplish is plugging everything up. The car needs a water pump. Replace it and flush the system to try to get some of that gunk back out of it. There is no such thing as "Mechanic in a Can"
Aug 20, 2010 at 1:15 PM
JCURTS75
  • 12 POSTS
just trying to make it last another 1.5 months until I have a down payment for another car.
Aug 20, 2010 at 1:18 PM
JCURTS75
  • 12 POSTS
also, the person who actually put the sealer in it added a lubricant as well. He said it would help cut down on gunking everything up. thoughts?
Aug 20, 2010 at 1:23 PM
WRENCHTECH
  • 20,761 POSTS
Nonsense.
Replace the water pump or park the car.
Aug 20, 2010 at 1:41 PM
