replaced camshaft sensor and crankshaft sensor.
also installed computer from salvage yard.
checking with snap on scanner reving up engine normal timing advances 15 degrees if i put a load on
the engine and floor the gas petal valves clatter and
timing advances 31 or 38 degrees. 15 degrees seems
normal to me. also i have replacer timing chain and
gears and tensioner.
this is the same car i asker about before.
do you thlnk salvage yard computer is bad or have i missed something
Jan 7, 2010 at 10:28 PM
