When my 96 cavalier z24 is cold, everything runs great. When it starts to warm up, however, the engine starts to have some problems. When I step on the gas, the engine sputters/flutters. This happens when the gas pedal is pushed down about 1/4-1/2 way or more. If I feather the gas pedal, it goes fine too. This also only happens when the rpm's are about below 3000. Above 3000, it is also fine. It almost seems like it is not getting enough gas when this happens. There are no trouble codes, the MAP sensor is good, TPS good, new coil pack. Any idea's? Thanks a bunch.
Nov 14, 2009 at 1:52 PM
