1996 Chevy Cavalier cavalier backfires
1996 CHEVROLET CAVALIER
194,000 MILES • 4 CYL • FWD • AUTOMATIC
when trying to start the car it backfires as i keep trying to start the car it still backfires then the muffler ends up with a hole in it. this has happened two times. any assistance would be apprectiated... thanks
Mar 18, 2008 at 3:36 PM
SERVICE WRITER
  • 9,123 POSTS
Sounds like a possible timing issue.
Is the car running?
Any check engine light?
Any details?
Mar 18, 2008 at 5:55 PM
the car does run, although sometimes i can't get it started, i have taken it to the shop and they are not for sure, they wanted to hook it up to a computer but the car would not read. so he is thinking the computer is out or there is a loose wire. he said the car was running fine so i went and got it and when i tried to start it, it took me 3 times. i called him and told him it was still backfiring and he said to put some gas in it and see what happens. well, it still back fired and my husband drove it for 2 days and it ran fine. so i go to drive it and it would not start after maybe 3 or 4 times it finally back fires so loud i figured i had better stop before i put another hole in the muffler and low and be hold it was to late. my husband came home and it started right up and yes the hole was in the muffler. although he says he would go out and turn the ignition over but not start it and turn it back and then start it. i have drove this car for 7 months and all of a sudden this happens. i am puzzled..... i think the engine light is on but it has always been on... let me know if you can help.... my dad feels that if it was the timing it would do it all the time... i don't know but i am willing to try anything....thanks in advance for anyones advice...
Mar 18, 2008 at 7:57 PM
SERVICE WRITER
  • 9,123 POSTS
Go take a look at that computer. Those were stuffed in the front of the passenger front wheel and were susceptible to moisture problems. Here in NF NY they would freeze and split open sometimes.
Pull that thing out and get a look at it and the connector going into it.
Mar 18, 2008 at 8:29 PM
ok i will have someone check this out. and let ya know what i find out. thanks alot for your assistance so far and i will probably be talking with you soon. thanks
Mar 18, 2008 at 8:50 PM
