1995 Chevy Cavalier Turn Signals Shorted Out
1995 CHEVROLET CAVALIER
270,000 MILES • 4 CYL • FWD • AUTOMATIC
SPICEYWEASEL
Fuse is good. Is there a turn signal module or one of those annoying little canisters in there somewhere? If it is the turn signal switch, how do I take the steering column apart without setting off the airbags?
Nov 16, 2009 at 6:29 AM
JDL
  • 16,098 POSTS
Welcome to the forum, there should be a multiwire connector under the dash, close to the steering column, that is for circuits going to and from the steering column. you can use testlite on some of those circuits. Purple wire carries voltage to turn signal switch, key on. From the turn switch, lite blue wire is left turn. Dark blue wire is right turn. Any time your working around steering column, repair info says to disarm airbag.
https://www.2carpros.com/forum/automotive_pictures/170934_airbag_1.jpg
I just wanted to add, there are safety issues concerning the air-bag, that is your responsibility.
Nov 16, 2009 at 9:38 AM
