i have a 1995 chevy cavalier with the 2.2 motor. when i start the car the first time it will idle and run fine. after getting up to normal temp. if i come to a stop light it will begin to chug and sputter, then eventually die. if i can get it started again, anywhere from about 30 mph on up it runs fine. but usually it doesnt start back up. i have replaced plugs, wires, fuel filter, and 'cleaned' the egr valve. (the vac. port was clogged) it acts like it doesnt get enough fuel when its chugging. i usually have to feather the gas pedal in order for it to stay running! HELP!!!!!!
Aug 15, 2010 at 7:40 AM
