Thanks for the info bluelightnin6...we were using a scan tool and it came up with the error code 15...Pass initiator circuit resistance high...we were scanning for the SRS error code at the time. I did not personally run the scanner, but the person who was using it, I am pretty comfortable with his knowledge of how to use it correctly. I had done a little searching and found the error code 15 has something to do with the coolant system, so now I am baffled...will have to go back and re-read the code and see if I missed something! Thanks again!!!
Aug 13, 2010 at 5:53 PM
