Engine Mechanical problem
1995 Chevy Cavalier 4 cyl
Recently bought a 95 Cavalier and yesterday I did some routine maintenance. I replaced the air filter, fuel filter, and spark plugs.
However this morning the car would not start and I noticed it smelled as if it were flooded. Upon inspecting under the hood I noticed gas leaking from the fuel injector closest to the fuel pressure regulator.
Being on a tight budget I plan on doing the repairs myself and was wanting some input on this. Could a bad fuel pressure regulator cause the o-ring on just one injector to leak? All I can afford right now is to either replace the FPR along with the leaking injector, or the FPR and the o-rings on all four injectors.
Feb 13, 2009 at 9:44 AM
