1994 Chevy Cavalier Turn Signal
1994 CHEVROLET CAVALIER
198,000 MILES • 4 CYL • 2WD • AUTOMATIC
KRYSTALPIKE
My turn signal was working then while ticking the ticking became long and drawn out and then it stopped working. there is no ticking sounds the inside arrows (green) are not showing up and the lights dont flash. I have replaced the turn signal mecinisum that goes by the steering wheel. I have replaced the flasher under the steering wheel concel The four way still works but not the turn signal.
Jun 11, 2009 at 8:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
By the turn signal mechanism, do you mean the turn signal multi-function switch? If you have replaced the switch and the turn signal flasher relay then there must be a fault in the wiring either to the switch or the relay.
Jun 11, 2009 at 9:51 PM
