1993 Chevy Cavalier turn sygnals
1993 CHEVROLET CAVALIER
ZEFIER
  • 6 POSTS
Electrical problem
1993 Chevy Cavalier 4 cyl Front Wheel Drive 213000 miles
my turn sygnals are not working, their not even getting power but the fourways work. i replaced the fuses, the switch and the bulbs work. what could it be?
Oct 25, 2008 at 8:35 PM
Hi:
Have you checked the flasher?
JOe
Oct 25, 2008 at 11:53 PM
ZEFIER
  • 6 POSTS
[quote:097f5e7d1c="Jacobandnickolas"]Hi:
JOe[/quote:097f5e7d1c]
yes, replaced it. zefier.
Nov 12, 2008 at 11:53 AM
ZEFIER
  • 6 POSTS
yes, replaced it.
Nov 12, 2008 at 11:57 AM
Hi: Have you been able to check power to the switch? If not, let me know and I'll look up the process for you and get back.
Nov 12, 2008 at 3:12 PM
ZEFIER
  • 6 POSTS
no not sure how. im not very good with wiring.
Nov 16, 2008 at 1:59 PM
Hi:
Does the vehicle have an air bag?
Nov 17, 2008 at 6:31 AM
ZEFIER
  • 6 POSTS
no
Nov 22, 2008 at 10:14 PM
Hi:
To check the switch, you'll have to remove the steering wheel to get to it. Once you do that, you'll need to check if power is getting to the switch. If you are not comfortable with this, you may want to have it checked by a mechanic.
Sorry it took so long to get back to you. I lost a parent on Friday, and ended up in the hospt myself.
Nov 23, 2008 at 3:48 PM
ZEFIER
  • 6 POSTS
sorry to hear about that. it hs a good switch. how do i check the power going to it?
Nov 30, 2008 at 1:55 PM
Hi:
Once you get to the switch, unplug the harness going to the switch. If it's only a signal switch, I believe there are 3 wires going to it. One will power in, the others out.
Let me know if you have something other than what I described.
Nov 30, 2008 at 11:58 PM
