1993 Chevy Cavalier radiator fan
1993 CHEVROLET CAVALIER
HMD07
Engine Cooling problem
1993 Chevy Cavalier 6 cyl 150000 miles
My fan is not kicking on causing the car to overheat when idling. Where can i find the relays to test if they are bad or if I have a burnt out fan motor?
Oct 11, 2009 at 12:46 PM
JDL
  • 16,098 POSTS
the fan relay should be under the hood, driver side fender area, not too far from battery. You can take fan connector loose, use jumper wires for voltage and ground from the battery to fan connector, to see if fan will run. Use inline fuse. If you unplug the cts, turn key on, the fan may run, if you turn on the ac, the fan may run, if you access codes using jumper wire, the fan may run.
Oct 11, 2009 at 1:14 PM
