1993 Chevy Cavalier Cavalier turns over but won't start
1993 CHEVROLET CAVALIER
220,000 MILES • 6 CYL • 2WD • MANUAL
DARRENDWILSON
  • 6 POSTS
I have a 93 Cavalier RS 3.1 Litre V6. I went to start it one day and it just turns over and won't start. I disconnected the fuel filter and used the fuel pump direct power feed under the hood by connecting it to the battery and the fuel pump turns on and shoots out gas. I checked the fuse under the dash and it is good, I replaced the fuel pump relay under the hood, and it still doesn't start. I took off the connecter to the relay, ran a wire to the battery from the connecter power line, and the fuel pump turns on and shoots out gas. I'm not sure why it doesn't work when I turn the key on and turn it over. Any suggestions? Does the ECM go bad on these things? Any help is appreciated!
Feb 14, 2010 at 9:53 PM
Did you check for spark?
Feb 14, 2010 at 9:58 PM
DARRENDWILSON
  • 6 POSTS
I didn't check for spark I guess I should have. I figured with the fuel pump not turning on when I turn it over I should get that figured out. I have the fuel filter off and when I turn it over the pump doesn't turn on and no fuel is coming out.
Feb 14, 2010 at 10:06 PM
Check for spark if you got it-concentrate on the fuel system-such as the fuel pump fuse, fuel pump relay,inertia fuel cut off switch and fuel pump.
Feb 14, 2010 at 10:10 PM
DARRENDWILSON
  • 6 POSTS
Ok will do thanks - I didn't know the cavaliers had a cut off switch. This might be kind of a dumb question but would the fuel pump not turn on when I turn it over because the fuel filter is off.
Feb 14, 2010 at 10:23 PM
Disregard the fuel cut off switch thought it was a ford-its been a long day
With or w/o the fuel filter in place fuel under pressure should come out-
Feb 14, 2010 at 10:27 PM
