My Cavalier RS 3.1L V6 shakes VIOLENTLY when I lift the clutch from a standstill and when I am driving. It idles well since I replaced the idle air control valve. It has regularly given me code 34 (map sensor- junk yard) which I have replaced a couple of different times with no success. It runs ok when it is cold but after it heats up, it shakes and dies when the clutch is lifted. If I rev the engine very high and ride the clutch slowly letting it up, it will go but then when i shift into second it does it again. I thought that it might be a vacuum leak somewhere but there seems to be good suction when I loosen the line on the map sensor, and I can't hear any hissing. also of a side note the heating system won't select any different vents it just comes out of all of them lightly. and the speedometer has hit maximum when I was reving the engine, but not moving. I have been struggling with this for a long time and any help is appreciated.
thanks
Dave
PS 315000KM not miles
thanks
Dave
Nov 23, 2008 at 8:38 PM
