1991 Chevy Cavalier idle surges up and down and bouncing oi
1991 CHEVROLET CAVALIER
130,000 MILES • 6 CYL • FWD • MANUAL
SEAN_ZACKER
i have a 1991 cavalier has a 3.1 v6 5 speed when the car is idling it idles up and down only sometimes and when the idle drops down and then back so does the oil pressure idk changed the tps and iacand no change almost like the engine is surging also has a miss only at idle cant find a vaccum leak anywhere
Nov 19, 2009 at 11:41 PM
MMPRINCE4000
  • 8,548 POSTS
Got to be a vacuum leak somewhere, IAC is attempting to compensate but can't because of leak.
Nov 22, 2009 at 7:51 AM
SEAN_ZACKER
i have checked all over i can here like a pss pss sound but might be the exaust cause its not all the way tight at the flange
Nov 22, 2009 at 8:36 PM
MMPRINCE4000
  • 8,548 POSTS
You can spray carb cleaner at suspected vacuum leaks, any change in idle is where the leak is.
Nov 23, 2009 at 7:02 AM
SEAN_ZACKER
ok i just did that and found nothing i need help
Nov 24, 2009 at 12:30 AM
MMPRINCE4000
  • 8,548 POSTS
You need a scanner that can read live data. Watch the movement of the IAC (called "steps").
Most shops can generate smoke that will migrate toward the vacuum leak.
You could try a compression and cooling system pressure test.
But it could also be a leaking injector seal, intake manifold gasket.
Also scan timing advance.
Nov 24, 2009 at 7:22 AM
