1991 Chevy Cavalier fuel injector replacement
1991 CHEVROLET CAVALIER
LILREDBAMA91
Engine Mechanical problem
1991 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
i am replacing 2 fuel injectors on my car and im not sure how to remove pressure from the fuel lines in order to replace the fuel injectors
Feb 10, 2010 at 11:31 AM
TOOOMANYTOYS
  • 513 POSTS
An easy way would be to remove the fuel pump relay and crank the car over till it will not start anymore. Then disconnect the fuel lines and pull the rail off.
Feb 10, 2010 at 11:40 AM
