1991 Chevy Cavalier Engine runs fine, then lean, then fine,
1991 CHEVROLET CAVALIER
DUBSHACK
Engine Performance problem
1991 Chevy Cavalier 4 cyl Front Wheel Drive 8900 miles
I think I've spent more trying to repair this car than we did on the damn car. We bought it at a used car lot in February of last year and it ran fine, and then about June we started having this problem. You would start the car from cold condition and get about as far as 2 to 6 blocks, stop to get into traffic, and press on the gas and the car would barely want to go, and sometimes flat out stall. We replaced the distributor wires, spark plugs, EGR Valve, MAP sensor, throttle position sensor, fuel filter, fuel pump, oxygen sensor, and finally the catalytic converter before the car stopped working entirely. My father in law towed it to his house and put a new starter in it, which the car would start but still had the problem. He took it to a mechanic up there who read the computer codes and replaced a sensor. (I don't know what sensor was replaced unfortunately) They said the car was working rough but fine and brought it back. The first day we went to get the car emissions tested we encountered exactly the same problem as before, so clearly the mechanic didn't fix it. I'm not exactly sure who besides God at this point is capable of repairing this vehicle, but we're running out of vehicles. The only other thing that I can say is that when I replaced the spark plugs one of them was completly soaked in oil. The salesman had told me the head gasket had been recently replaced, and it appeared there was minor oil burns coming from the top plate of the engine. (I don't know what this is called, sorry) I have checked since and have not seen this same oil leak since. I'm at a complete loss as to what could be the problem here.
Jun 20, 2008 at 11:13 PM
Do an engine compression check both dry and wet test and report back with your readings this is where we start to hunt down this culprit. Oh! also if you could do a fuel pressure check I need that too-
Jun 20, 2008 at 11:29 PM
DUBSHACK
Sorry it took so long to reply. I'm not sure what the difference between a "dry" or "wet" compression test is, or how to do a fuel pressure test but I borrowed a compression guage from my dad and from left to right I got 160psi, 161, 160 and 200. Interestingly enough before I did the compression test I noticed the same oil leak as before in the spark plug chamber again, same chamber, and this is the one running at 200.
Jul 29, 2008 at 9:49 AM
