1989 Chevy Cavalier Clogged Fuel Injectors
1989 CHEVROLET CAVALIER
90,000 MILES • 6 CYL • FWD • AUTOMATIC
CSL24
Hello, My car as been constantly going dead after 20 minutes or less when idle. Its impossible to drive when any pressure is on the accelerator as well. We have replaced the ignition module, replaced the coil, replaced the spark plugs, battery is good, alternator good,ECM good, and the plug wires too. We think the Injectors or at least some are clogged to the point when the gas can not flow through properly, resulting in the 20 or less minute shut off. Question, can a clogged fuel injector or injectors result in something like this? Please any input would be great. Have a nice day,
Jan 15, 2010 at 4:17 PM
DJGOLD
check your catalytic converter to see if its blocked.if its glowing red after running it it is blocked and you need to change it.
Jan 21, 2010 at 8:53 PM
