1989 Chevy Cavalier 1989 Cavalier fuel injectors
1989 CHEVROLET CAVALIER
RMOREY
Engine Performance problem
1989 Chevy Cavalier 6 cyl Automatic
Looking for correct ohm reading for my fuel injectors. I had tested them with an ohm meter. Haynes book gives range of 11.8 - 12.6. I have 1 injector that reads 11.8; 2 that read 11.9; 2 that read 11.6; and 1 that reads 11.1. Are the 11.6 and 11.1 readings low enough to warrant having them replaced?
May 20, 2008 at 6:49 PM
MMPRINCE4000
  • 8,548 POSTS
Are you having a secific problem?
The lower the resistance the more amps it will take to fire the injector (ohm's law).
It sounds like the injector is towards the end of its life. If resistance gets too low and amps exceed the fuse capacity, it will blow the fuse.
The readings you gave just indicate the injectors are wearing out, and will need to be replaced at some point.
May 22, 2008 at 5:33 AM
RMOREY
I have spark and correct fuel pressure. Car will turn over but not start. I replaced 1 injector about 6 months ago. Car has same symptoms, no codes.
[quote:07b3975c44="mmprince4000"]Are you having a secific problem?
The readings you gave just indicate the injectors are wearing out, and will need to be replaced at some point.[/quote:07b3975c44]
May 22, 2008 at 6:18 PM
MMPRINCE4000
  • 8,548 POSTS
If you have spark and fuel pressure is good, then I would get a noid light and see if the injectors are getting the signal to fire. If not, then the fuse is out or the injector driver in the ECM.
If this is a multi-port 2.8-3.1 the injectors fire in batch sequence i.e. 1-3-5/2-4-6. So there should be two fuses for the injectors.
May 23, 2008 at 5:28 AM
