94 Caprice, 4.3L V-8
1994 CHEVROLET CAPRICE
THEYCALLMELISSA
Please help! I have a 94 Chevy Caprice, approx mileage is 189,000, it's a 4.3L V-8, automatic. It's stalling, not when driving it, but sometimes when you stop. It's "jumping" when you are stopped and occasionally when driving down the road. It's leaking anti-freeze, but we can't tell from where. There is a little bit of black smoke coming out the exhaust. Power steering gets tight also sometimes. The fuel filter, alternator, plugs and wires, distributor are only approx 2 months old (brand new when purchased). The fuel pump is only about a year old. Any help you can give is soooooooo greatly appreciated!!!!
Thank you so much! Melissa
Oct 18, 2007 at 8:14 PM
BMRFIXIT
  • 19,053 POSTS
[quote:79425b7e84="TheyCallMeLissa"]Please help! I have a 94 Chevy Caprice, approx mileage is 189,000, it's a 4.3L V-8, automatic. It's stalling, not when driving it, but sometimes when you stop. It's "jumping" when you are stopped and occasionally when driving down the road. It's leaking anti-freeze, but we can't tell from where. There is a little bit of black smoke coming out the exhaust. Power steering gets tight also sometimes. The fuel filter, alternator, plugs and wires, distributor are only approx 2 months old (brand new when purchased). The fuel pump is only about a year old. Any help you can give is soooooooo greatly appreciated!!!!
Thank you so much! Melissa[/quote:79425b7e84]
Check the intake manifold for the antifreeze leak
And also if you have a vacuum leak
Steering is it happening when the car stalling
If not u may need a rack & pinion
Make sure you P/S fluid full
Good luck
Oct 18, 2007 at 8:25 PM
THEYCALLMELISSA
Thank you so much for your advise. No, the steering is tight occasionally when driving also, but not at higher speeds, only when slowing down to say a light, or taking off. I'll check the P/S fluid and the others that you advised. Thanks so much again!!
Oct 18, 2007 at 8:38 PM
BMRFIXIT
  • 19,053 POSTS
[quote:81c885a75c="TheyCallMeLissa"]Thank you so much for your advise. No, the steering is tight occasionally when driving also, but not at higher speeds, only when slowing down to say a light, or taking off. I'll check the P/S fluid and the others that you advised. Thanks so much again!![/quote:81c885a75c]
If the steering tighten up and loosen all of sudden you may need a rack & pinion
Good luck
Oct 18, 2007 at 8:45 PM
THEYCALLMELISSA
Thank you, you've been a great help!
Oct 18, 2007 at 8:48 PM
