2000 Chevy Blazer chronic fuel pump failure
2000 CHEVROLET CAPRICE
GERALD HARDCASTLE
Electrical problem
2000 Chevy Blazer V6 Four Wheel Drive Automatic 150000 miles
replaced fuel pump and filter. New connector and harness. 1 month later +/- engine is starving for fuel at about 2,500 rpm....replaced again same thing about 5 wks......replaced and about 6 wks later time to do it again.....can anyone give a suggestion??
Dec 12, 2008 at 7:04 AM
MIKE H R
  • 3,094 POSTS
I am not much on the electric fuel pump I try to work with older cars, but off hand I would have the voltage checked going to the pump. Also check the ground. Too little voltage will burn out the pump.
Dec 17, 2008 at 1:58 PM
DOCFIXIT
  • 18,828 POSTS
Check ground and are you installing GM OEM pumps? If not that is likely the early demise
Dec 17, 2008 at 2:13 PM
