1996 Chevy Caprice car cutting off
1996 CHEVROLET CAPRICE
105,000 MILES • V8 • FWD • AUTOMATIC
CWILLTHEGREAT
sometimes while im driving especially when making turns the car cuts off and the power steering goes out and its says check gauge on the dash...can anyone help?
Jan 18, 2010 at 12:07 AM
ERNEST CLARK
  • 1,730 POSTS
Your power steering will quit anytime your engine shuts off.
The reason your engine dies is either an ignition or fuel issue.
You'll have to isolate these systems until you find the source of the problem.
Begin with checking the quality of your spark. If it isn't a crisp blue all the way through the r.p.m. range, trace the ignition system backwards to the coils until you find the problem.
If this checks out, go to fuel next. Begin with a fuel pressure test. Then check the injectors.
Also, inspect all of your vacuum lines and fittings.
Mar 7, 2010 at 8:43 PM
