1992 Chevy Caprice car cutting off
1992 CHEVROLET CAPRICE
170,939 MILES • 6 CYL • 4WD • AUTOMATIC
DREFESHA
I recently bought a 92 Chevy Caprice from a private owner. All seemed fine at first but then the car started cutting off on us. it seems whenever I stop giving it gas it starts to cut off. I have to throw the car in neutral and give it gas repeatedly just to keep it from cutting off at red lights. Also as soon as you crank the car up it sounds like its idling and wants to cut off but then runs smooth until you put it into gear, and then the problem I stated earlier persist.
May 1, 2008 at 5:22 PM
BLACKOP555
  • 10,386 POSTS
check for vaccum leaks first of all, might be best to take it in and have a smoke test done. also sometimes it may be a sign that your idle speed is too low due to it being misadjusted or a bad IAC module also a dirty throttle body can cause this also.
May 1, 2008 at 9:09 PM
