1991 Chevy Caprice heater core
1991 CHEVROLET CAPRICE
170,000 MILES • V8 • 2WD • AUTOMATIC
CRAFTWICCAN
i need to know the location of the heater core
Oct 21, 2008 at 3:46 PM
Hi:
If you need to replace the heater core, it's on the passanger side interior. Right above where the passenger's feet would go is a panel. Use a nut driver to remove all the hex screws. I believe they are 7/16". Pull the panel off and then there is a black, pan-looking thing also held on by the same size hex screws. Remove all of them and the brace and pull the pan off. Look up there and you will see the heater core bigger than Dallas. You will have to disconnect the leads from under the hood then pull the thing out. I wouldn't even drain the radiator but you need to be careful not to have it leak all over.
Put in the new core and rehook everything up. Run the engine up to temeperature with the heater and fan on full. Top off your collant and you are good to go.
IF you have any other questions, let me know.
Oct 29, 2008 at 8:54 AM
