1991 Chevy Caprice black smoke
1991 CHEVROLET CAPRICE
148,000 MILES • V8 • 2WD • AUTOMATIC
RUBENTINA
my wagon throws out a puff of black smoke every time i floor the gas pedal then goes away then at a stop sign i try it and it will do it again but it won't do it if i take off smoothly,i changed wires cap,rotor,plugs and fuel regulator,what can it be the engine runs good but will not pass smog as it runs too rich,please help.
Aug 26, 2008 at 2:36 PM
Possible causes include a bad O2 sensor, excessive fuel pressure (bad fuel pressure regulator or plugged return line), leaky fuel injectors, dirty air filter or restricted air inlet, or a defective coolant sensor that prevents the engine management system from going into closed loop mode.
Aug 26, 2008 at 2:44 PM
RUBENTINA
what would be the first thing you would do to figure this out?
Aug 26, 2008 at 2:53 PM
Check the airfilter then fuel pressure could be excessive due to the regulator or clogged return line-
Aug 26, 2008 at 3:01 PM
