1990 Chevy Caprice Thermostat replacement
1990 CHEVROLET CAPRICE
TINTIN'MAGICIAN
Engine Cooling problem
1990 Chevy Caprice V8 Two Wheel Drive Automatic
Hi, how do you replace the thermostat on a 90 caprice classic brougham? What tools are needed?
Oct 8, 2009 at 12:58 PM
BLUELIGHTNIN6
  • 16,542 POSTS
REMOVAL & INSTALLATION:
Drain the cooling system to below the thermostat level.
Disconnect the upper radiator hose from the thermostat housing. Loosen the clamp on the coolant by-pass hose, on the 5.0L (VIN Y) engine only.
Remove the two retaining bolts or studs from the thermostat housing and remove the thermostat.
Use a new gasket when replacing the thermostat.
Fill and bleed the cooling system.
Oct 9, 2009 at 1:59 PM
