problem with high beams on camaro
CHEVROLET CAMARO
CRAZYLULU
i just bought a 1993 camaro z28, automatic, 58000 miles, went to get it inspected, and they wouldnt pass it because of the high beams dont come on, all other lights work, the switch you pulll forward sometimes the high beams come on, but wont stay on, the handle is kinda loose, but if you jiggle it, the hight beams do come on, but wont stay, what can i do, thanks
Jul 17, 2007 at 10:12 AM
CWEATHERLY
I have a 91 RS and I have the same problem. I finally figured out that if I hold the tilt lever and pull the steering wheel all the way down and then pull the high beam lever it will stay on. But you have to hold the steering wheel all the way down. try that
Aug 23, 2007 at 7:07 AM
