My IROC has an electrical problem
CHEVROLET CAMARO
IROC1989GRL
I have an '89 IROC Camaro with 89,000 original miles and a 5.0lt engine. Most of the engine is still original. We just had to replace the radiator because it got a hole in it. When we went to start it after driving it to a oil change the next day, it will not even turn over, it does not even click. We replaced the started, that did not fix the problem. We checked everything mechanical with the car and we have even narrowed it down to electrical wiring probably. Could you stear me in the right direction of where to start looking for the problem, or what type of place in Orlando, Florida, that I should look at to take my car to to have them fix it?
thank you.
Sep 13, 2007 at 3:06 PM
1987IROC
Did you check all of your grounds on your firewall and your ground coming off the negative terminal on the battery, somehow it may have been knocked loose during oil change. Do you have any power to your radio, lights, etc...? i'm actually having trouble with my wiring on my 87iroc right now. Mine turns over but i believe its had a wire bitten by a mouse going to the fuel pump, because its not getting fuel to injectors. Any more information you can give will help anyone who recognizes the problem. Sorry if im no help, just getting the ball rolling.
Sep 25, 2007 at 8:26 PM
