Frustrated and lost
CHEVROLET CAMARO
ROTIKDREAMS
[i:5f44bc072b][color=blue:5f44bc072b][/color:5f44bc072b]
I have a 1991 Chevrolet Camaro Z-28 and it has 94,000 miles. I have a computer problem with the car that has left both myself and every mechanic that I have taken it to thoroughly lost. I've replaced the entire computer three times so far because every computer I put in there has done something else to the car other than fix the problem. I've already re-wired the car twice due to things shorting out. We originally fixed the computer to fix the speedometer. It still doesn't work and the sensor that runs it is fine. Fuses blow in the car now. I can light a cigarette from the car lighter and blow every fuse in the car. I replaced the window motors with new ones because they died somewhere near the second computer replacement and they still don't work right. The trunk is power and it won't work either. If I blow the horn, I blow every fuse in the car. To make matters worse I've replaced the thermostat three times now as well and the car keeps overheating. Chevy told me that the computer is not the problem. I've had 3 electricians look at the car and check the wiring, the computer, all the sensors, and fuses and everything is deemed in perfect working order so what I can't figure out is why these things keep happening? Can anyone give me a suggestion on where I should look next? I'm so lost right now and short of tearing the car apart and building it myself...I've no idea where to look next.[/i:5f44bc072b]
Apr 5, 2006 at 10:55 PM
PEPPERMRJ
  • 1,158 POSTS
Post in the GM section. Maybe lozone can help you out.
Apr 6, 2006 at 8:31 PM
BENZ_GUY
  • 28 POSTS
First off - make sure your battery is in excellent condition. Have it tested with a "good" battery tester. (Low voltage = high current, which can blow fuses.) Ohm's Law
Check all your ground connections and the Voltage Regulator/Alternator system.
Seems you're pushing quite a bit of current to pop all of the fuses, specially if they're all going at once.
I'll check out the wiring diagrams for your car and post more info if I see something that could be the culprit.
hope this is usefull to you.
Apr 12, 2006 at 1:48 AM
