My brother and I have just replaced the radiator on our older brother's camaro. The camaro was running hot all the time. The old radiator was filled with rust and made the water pump go bad, so we replaced that as well. So his car now has a new water pump, radiator and hoses. The leak from the water pump is no longer there but now in a different spot. After filling the car with radiator fluid and water, we noticed a leak of water underneath. I had traced it to a hole in the transmission case. Actually the hole is in the Torque Convertor access cover. I also noticed water pouring out from the transmission pan, or atleast it looked as if it was coming from there. We are stumped and need help!!!
Apr 5, 2007 at 4:00 PM
