gentlemen: my camaro just started intermittently going from normal temperature to HOT approx 260. This is after vehicle sitting for over 2 hours. It then overheats after driving approximately 12 miles. Again this is only happening once in a while.
I was advised by a garage mechanic that the radiator should be flushed, temp sensor replaced, fluids replaced and radiator cap replaced.
Do you know of anything that could be causing this.
I will have the work done as soon as possible and should it happen i should do the following:
1 ) pull over
2) ?
3) ?
4) ?
thank you for any information you can provide
1 ) pull over
2) ?
3) ?
4) ?
Oct 20, 2010 at 9:47 PM
