2001 Chevy Camaro Oil Leak
2001 CHEVROLET CAMARO
122,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROBERTREED21
I have an oil leak coming out of a circle that is about 1 inch in diamater that is located just above the oil filter (about an inch and a half). Although I don't know what this part is. The car is a 2001 Camaro 3.8L V6. I believe it is engine oil.
Oil is coming out of the hole, not sure why or how. Just wondering what the issue may be.
Thank you
robert
Oct 16, 2009 at 1:41 PM
DOCFIXIT
  • 18,828 POSTS
That would be a freeze plug I believe
Oct 16, 2009 at 3:54 PM
ROBERTREED21
Thanks, although I recently had no oil pressure coming from the oil pressure sending unit. And low and behold thats exactly what it was. The sensor broke off somehow a couple days ago. and eventually yesterday it blew through it. Replaced it and did a quick oil change and filter replacement. Everything is ok though.
Thank u for your reply.
Oct 17, 2009 at 10:27 AM
DOCFIXIT
  • 18,828 POSTS
So blew out the plastic part of switch? That's someting I've never seen leaks yes
Oct 20, 2009 at 6:55 AM
