2000 Chevy Camaro Changing sparkplugs on right side of engi
2000 CHEVROLET CAMARO
61,000 MILES • V8 • 2WD • AUTOMATIC
SROBERTS27
What's the procedure to get them out and replaced? Can't hardly see them let along get a plug wrench on them.
Oct 18, 2010 at 2:01 PM
JDL
  • 16,098 POSTS
Some GM vehicles, the plugs are easier to get from the bottom? Safely raise and support the vehicle, if you try from the bottom. You have to use your own initiative and judgement, what's easy for you, might not be the easiest for me. I'm not aware of any step by step procedure?
Oct 18, 2010 at 2:27 PM
JRD100
  • 11 POSTS
on my 2001 Camaro I cut down a spark plug socket and used a Gear wrench to turn it. it works fine with minimal troubles.. You actually tunnel yourself forward just under the coil packs working your way forward They actually sell the modified sockets on e-bay now. Hope this helps..
Oct 21, 2010 at 10:18 PM
