1999 Chevy Camaro low coolant light
1999 CHEVROLET CAMARO
86,200 MILES • V8 • 2WD • AUTOMATIC
TYLERMAX
  • 17 POSTS
What could cause a low coolant light to come on, even though there is plenty of coolant in the system? Also, the car is not overheating, it's running fine, just the low coolant light will not go off even though there is plenty of coolant in the system.
May 31, 2008 at 1:58 PM
MERLIN2021
  • 17,250 POSTS
If the plastic recovery tank is more than half full it should go out, if not replace the sensor in the tank.
May 31, 2008 at 2:00 PM
TYLERMAX
  • 17 POSTS
okay, so i am finding out that for some reason this only happens once the car is driven around for a while, and once it cools off for a few hours the light does not appear anymore. Would this additional info. change your answer in any way?
May 31, 2008 at 6:17 PM
MERLIN2021
  • 17,250 POSTS
No...have you checked the coolant level in the tank?
May 31, 2008 at 7:41 PM
TYLERMAX
  • 17 POSTS
yes i checked the coolant level in the tank, and there is definitely plenty of coolant in there.
Jun 1, 2008 at 9:17 PM
MERLIN2021
  • 17,250 POSTS
Then either the sensor, or circuit, or gauge is defective..I go with the sensor.
Jun 2, 2008 at 5:18 AM
