1999 Chevy Camaro hydralic clutch
1999 CHEVROLET CAMARO
75,000 MILES • V8 • 2WD • MANUAL
BILL SCHRAMM
replaced clucch and all componets bleed system time and time cant seem to get right clutch pedel is there trick to bleeding or maby something else wrong
Sep 22, 2008 at 10:19 AM
MMPRINCE4000
  • 8,548 POSTS
If the MC is higher than the slave you can simply gravity bleed the system. Make sure the lines are tight and not leaking.
Have someone depress the clutch and watch the slave rod for movement, should move immediately when the clutch is depressed.
Make sure the slave is bolted tight and the bracket is not cracked.
Sep 23, 2008 at 7:10 AM
