1998 Chevy Camaro Windows controls and radio go out occasio
1998 CHEVROLET CAMARO
191,000 MILES • 6 CYL • 2WD • AUTOMATIC
JLW4HIM
My 1998 Camaro convertable has a random problem-in the middle of the day, when the temp is high, the electric windows go out, the radio stops, and the top won't go down. You can start out and all things work, then the go out and might come back on. Later that day or the next day, all seems fine. History, pulled the motor last year and put a new head gasket in and several other parts. That was over 1 year ago, and this new situation just came up.
Aug 22, 2009 at 6:52 PM
BMRFIXIT
  • 19,053 POSTS
I would suspect a bad ignition switch
next time it happens try and wiggle the ignition key
and if radio come back and or flicker for sure suspect and change ignition switch
good luck
Aug 23, 2009 at 7:53 AM
