1998 Chevy Camaro when engine gets hot it dies out
1998 CHEVROLET CAMARO
BK09086
  • 12 POSTS
Engine Mechanical problem
1998 Chevy Camaro 6 cyl Two Wheel Drive Manual
the car runs fine when it is cool and when engine warms up it dies out. It is giving me a code of P0341 camshaft sensor. I have replaced the sensor and same thing. Also had coils tested and ignition control module tested at Autozone. They did find 1 coil bad and I replaced it. Ignition module tested good.Still the same results. I am wondering if it tested good because it was cool at the time ?
Jan 6, 2009 at 3:33 PM
RHALL77
  • 3,361 POSTS
does it start right away when it stalls or does it have to cool off
Jan 6, 2009 at 6:42 PM
BK09086
  • 12 POSTS
It has to cool off
Jan 6, 2009 at 7:45 PM
BK09086
  • 12 POSTS
[quote:0ccc20f90a="rhall77"]does it start right away when it stalls or does it have to cool off[/quote:0ccc20f90a] I clear the code and it comes right back as well
Jan 6, 2009 at 7:49 PM
BK09086
  • 12 POSTS
feedback would be appreciated thanks for your time
Jan 7, 2009 at 9:07 AM
RHALL77
  • 3,361 POSTS
sorry i was working all day. check and see if there is 5 volts to the connector that plugs into the cam sensor. if you have access to a scanner also make sure the cam is sending a signal to the pcm. sounds to me like its a module heating up and causing your stall but lets start here to be sure first.
also in the future so you know, i am not always online, i usually check my replies once a day, so if i dont get back to you right away im sorry. I will do my best to help you out.
Jan 7, 2009 at 4:10 PM
BK09086
  • 12 POSTS
this is a 3 wire plug. white with black stripe- 10.8v
red with black stripe- 9.9mv
brown with white strip-6.72v
I think the pcm is recognizing the cam sensor. I do have a code reader and when i clear the code and go back and check it has no codes set. when i unplug the sensor it does throw a code. all with engine running before it gets to hot and dies out. when the engine does die out with the sensor plugged in it throws that P0341 code
Jan 8, 2009 at 9:11 AM
RHALL77
  • 3,361 POSTS
do you know if the coils are arching on the module? something to look at. disconnect the ingnition module then retest the wires for voltage. make sure there isnt a short to voltage or a short to ground. there should only be 5 volts to the sensor. I think you need a ingnition module or you have a short to voltage. let me know what you find.
https://www.2carpros.com/forum/automotive_pictures/166241_222553_1.jpg
Jan 8, 2009 at 9:49 PM
BK09086
  • 12 POSTS
when i unplug the ignition module i have no voltage to the cam sensor
Jan 11, 2009 at 5:00 PM
RHALL77
  • 3,361 POSTS
check the resistance between circuirt 633 and ground and let me know what you find
Jan 12, 2009 at 10:25 AM
BK09086
  • 12 POSTS
do you want me to check that circuit with the igniton module unplugged are plugged in
Jan 12, 2009 at 11:15 AM
RHALL77
  • 3,361 POSTS
yes disconnect it. also check the resistance between the connecter and the connector for the module. this will check and see if the wiring is good
Jan 12, 2009 at 11:55 AM
BK09086
  • 12 POSTS
the resistance between circuit 633 and ground is infinite. the reading is meg ohms
Jan 13, 2009 at 2:42 PM
RHALL77
  • 3,361 POSTS
if you have them both disconnected, and your testing each end of it, sounds like a open wire. start chasing wires and see what you find
Jan 13, 2009 at 3:33 PM
BK09086
  • 12 POSTS
can you be more specific. I was just testing the resistance on the signal side and the ground side of the cam sensor.
Jan 14, 2009 at 1:05 PM
RHALL77
  • 3,361 POSTS
i want you to disconnect the ing. module and cam sensor and test the 3 wires. resistance between the connector of the cam sensor and the ing. module.
Jan 14, 2009 at 2:20 PM
BK09086
  • 12 POSTS
the resistance between the cam sensor and ign. module on all three wires is 1.1 ohms.
Jan 17, 2009 at 9:59 AM
BK09086
  • 12 POSTS
ok i replaced the ignition module and the car runs great. drove the car for about thirty miles and no stalling issues. but the check engine light came on. i scanned it and it is giving me a code of P0336 crankshaft position sensor. no driving or cranking problems though any advice?
Jan 19, 2009 at 5:52 PM
BK09086
  • 12 POSTS
just to further reply to my question. the rpm gauge is a bit jumpy as well
Jan 19, 2009 at 9:51 PM
