i bought this car about 4 months ago and noticed that both gauges didnt work but i bought the car anyway cause i thought it would be something easy to fix. Well..... i took it to a shop and they did not know what was wrong with it. what it does it when u turn the car on the oil gauge goes all the way over to the other side as if the pressure way really high and the temp gauge stay down as if it was hot at all. and this is under normal driving (on the highway or in town) but as soon as you stopat a light or anything with the car still running but the car not moving the temp and oil gauge go to where they should be when the car is running but when the car starts moving again the gauges go right back to the same spot they did before. I just dont know what to do and i dont like to drive the car cause i dont know if it is over heating or the oil pressure is to much or whatever it maybe and i was hoping maybe you might know what is causing this thank you for your time
Aug 4, 2008 at 10:14 PM
