The initial issue occurred as the clutch pedal went to the floor and would not disengage (according to my wife as I was out of town). The 1998 Camaro Z28 - 6 speed manual was towed and the clutch master cylinder was repaired. During my first test drive upon my return, I noticed the shifting was not as smooth - particularly from 2nd to 3rd and then 5th to 6th. When the car is at a full stop and the clutch engaged, it will not shift at all from 2nd to 3rd nor 5th to 6th. It is drivable if you are cautious but I need to get to the root problem and have it repaired properly. This car is not driven hard. The EGR valve was also replaced with the master cylinder as I had been putting this off over the last 5,000 miles.
Any help with potential areas to diagnose or suggestions to repair would be appreciated.
Nov 28, 2008 at 5:03 PM
