1998 Chevy Camaro my doors lock automatically
1998 CHEVROLET CAMARO
130,000 MILES • 6 CYL • 2WD • MANUAL
SEAN080844
i lock my dorrs after i leave the car. when i come back to use the keyless entry it will only re-lock it wont unlock. even if your in the car with it off if you sit for a min or two you cant unlock the doors electronically you have to do it manually. is there some type of fuse i can remove to disable this feature? i believe the feauture is stopping my after market keyless entry from working by stopping me from unlocking the doors electronically. i have to do it manually with a key.
Mar 15, 2009 at 5:24 PM
JAMES W.
  • 2,394 POSTS
Not knowing what make remote you have, it obviously ties into your lock/unlock system. I would first check these connections. The remote unit, the part on your keyring, sends out 2 different frequencies. One for lock, and one for unlock. Either it's not sending the unlock signal. Or the receiver isn't processing the signal. If you have any paper work on the unit, there may be a test procedure there, Otherwise, you could check with the dealer or supplier. Hope this helps.
Mar 15, 2009 at 6:45 PM
