The fuel pump on this car failed and was extracted by cutting a hole in the floor of the car. a replacement pump was purchased and fitted, the pump produces pressure and fuel up to the pressure regulatin valve positioned aft of the rocker cover and very inaccessable, we know it is coming there as fuel appears when breaking in to the line at the wheel arch. no fuel after the valve, when schrader valve depressed, to telieve system pressure nothing evident. I am dubious of the failure of two components similtaniously and would like to know if anyone could shed some light. I do not know what the cylinder layout is as the car belongs to a work coligue and I'm just helping with research however I do know it is 5.8 Litre, and late 1990's, thanks in advance. Mike.
Mar 20, 2010 at 10:25 AM
