1997 Chevy Camaro no spark
1997 CHEVROLET CAMARO
BILLYCAMARO
Electrical problem
1997 Chevy Camaro V8 Two Wheel Drive Automatic
i have a 1997 camaro with a lt1 350 thats not getting spark most parts are new the opti cap rotor module coil even a up grade ingition msd dig6 plues but have tried with new and old parts and get not spark turns over like it wants to but will not fire up short of the computer everything is new could it be the computer and still let evrything else work normally?
thank [email protected]
Oct 26, 2009 at 11:27 AM
JDL
  • 16,098 POSTS
Welcome to the forum, did you check primary circuits at the coil? Pink wire is voltage goes hot when you turn on the key. Green wire is ground, should be a pulse on that wire, engine cranking.
Oct 26, 2009 at 11:47 AM
