1997 Chevy Camaro fuel pump
1997 CHEVROLET CAMARO
RONISACE
Engine Mechanical problem
1997 Chevy Camaro V8 Front Wheel Drive Automatic 110.00 miles
My wifes camaro is a 1997 camaro with 110.000 miles she drives to work every day she parked it and tried to start next day but it sounds like it wants to start then sounds like it is not picking up gas question where is the fuel pump and do you thank that is the problem thanks for the help and how hard are they to changee thanks Ronisace--- we unpluugged something from that we thought was a egr sensor but we do not thank that is what it is but when we plugged it back in it worked what is that valve called with vacum lines on it. A man at avance said it was the pressurecontrol what dose it control thanks for any help ronisace
Jan 2, 2009 at 4:44 AM
MNDWDS
Good Luck on the pump! That was one of the many things we have done on my daughter's car. If you pay someone to fix it--good luck!! $800 around here. We talked to a friend and he gave us a few shortcuts-- first open the gas tank, let it breathe, then return it. Crank the car and see if you can hear it "run" or 'pump" gas. If not, that is the first thing to have checked. If you are going to have to replace the fuel pump, do it yourself if you are handy with cars. It is in the rear behind the back seat. Pull up the carpet. There is your gas tank. We took some chances here but in the redneck way of life- we cut a large hole in the top of the tank and found the pump. From here, you can take it out and replace it. If you can't do it yourself, the mechanic will remove the whole back-end of the car, drain the gas tank, etc, etc, etc. That is why it is so expensive--labor and time. Good luck!! Hope that is the fix or just the filter. It's not a bad idea to have those checked or replaced - about $75 parts and labor, unless you can do it yourself. Good luck!!
Jan 2, 2009 at 1:01 PM
