1997 Chevy Camaro 3800 series 2 engine prolems
1997 CHEVROLET CAMARO
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
BRYANMACIAG
I just put a motor in this car. Replaced upper and lower intake gaskets. and rear seals notting else. Now the motor is blowing compression out the intake so hard it blowed one of my intake lines off and it has burned up two new starters. The back of the starter gets so hot you cannot touch it then kick out.. What is wrong with my camaro guys????
Apr 5, 2010 at 12:28 PM
INTERNETMECHANIC
  • 700 POSTS
Did the donor motor come out of a running vehicle? Sounds like an internal engine problem. I'd probably have to go through the engine.
Apr 5, 2010 at 12:39 PM
