1995 Chevy Camaro electric windows
1995 CHEVROLET CAMARO
D.G.B.
Electrical problem
1995 Chevy Camaro 6 cyl Two Wheel Drive Automatic
drivers side switch works drivers window up and down. also express module works going down. passenger window switch on drivers side only works passenger window up but not down.passengers side switch only works up but not down also.any clues??
Aug 14, 2008 at 1:49 PM
D5NUKE
  • 61 POSTS
You have a bad connection to the down line on the passenger side window.Either the wire is broke or the switch on one of the sides is open when trying to move it down.Its a DC motor so all your really doing is reversing the positive and negative to the motor.Check you switches for good contact and look for a ground on that wire.
Aug 19, 2008 at 1:31 AM
