1995 Chevy Camaro
1995 CHEVROLET CAMARO
BUFORD420
Electrical problem
1995 Chevy Camaro 6 cyl Two Wheel Drive Automatic
I DROVE MY CAMARO AROUND ONE DAY AND THE NEXT IT DIDNT START. IVE REPLACE THE STARTER,RELAY,AND IGNITION CYLINDER. I JUST NEED SOME DIAGNOSTIC HELP
Feb 23, 2010 at 10:40 AM
JDL
  • 16,098 POSTS
Your saying the starter won't crank? Battery has a full charge and connections are good? Do you think your theft system might be causing an issue? The purple wire, S terminal, at the starter solenoid should be hot, with key in the crank position. Testing around the starter, make sure the tranny is in park or neutral and the e-brake is set.
Feb 23, 2010 at 10:49 AM
Is the problem that the starter isn't working?
