1994 Chevy Camaro my car gets to hot
1994 CHEVROLET CAMARO
145,000 MILES • V8 • 2WD • MANUAL
007JUAN
my camaro gets olmost at the red on my gage end then the fan stars in. I took the termostat and still does the same what could it be
Sep 8, 2009 at 9:15 PM
Could be a clogged radiator or defective water pump-could also be air in the system if all checks out-get it block and pressure tested.
Sep 9, 2009 at 2:35 AM
CON_FUSE9
  • 8 POSTS
Step 1 normally would be to see if the car is really running hot. Because of the high compression, the LT1 runs a bit cooler than most - to avoid detonation. A non-contact thermometer will tell you in an instant. You can also scan the computer to see what temperature the computer thinks the engine is at.
If you haven't had the coolant system flushed in a while, you might consider this option as well. On the Camaro I would flush the heater core separately (notorious for collecting junk). The quick oil change places usually offer this service. Just make sure they open the bleed valves when filling the system.
All the above assumes also no damage to the lower skirt of the car. The small opening in the front of the car means the car gets most of its cooling air from under the car. That skirt has to be there (at least mostly there - darn low car....)
Sep 11, 2009 at 3:55 PM
