1994 Chevy Camaro Coolant leaking
1994 CHEVROLET CAMARO
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
TONYASUE98
What would make the coolant bubble up out of the overfill? It isn't leaking out anywhere else and you can see around the cap where it has come out there. Could it possibly be the thermostat?
Feb 2, 2009 at 5:55 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:c444cd9280="tonyasue98"]Engine Cooling problem
1994 Chevy Camaro 6 cyl Two Wheel Drive Automatic 200000 miles
What would make the coolant bubble up out of the overfill? It isn't leaking out anywhere else and you can see around the cap where it has come out there. Could it possibly be the thermostat?[/quote:c444cd9280]
If the vehicle is not overheating it could just be a bad radiator cap.
If it is overheating it could be the thermostat.
Feb 2, 2009 at 6:00 PM
TONYASUE98
No, it's not overheating, but I've also been having trouble with the heat not getting hot sometimes and I wondered if maybe that it could mean it was the thermostat. Thanks for the help! I was just hoping it wasn't something that was going to cost an outragous amount of money to repair.
Feb 2, 2009 at 6:08 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2f7b422567="tonyasue98"]No, it's not overheating, but I've also been having trouble with the heat not getting hot sometimes and I wondered if maybe that it could mean it was the thermostat. Thanks for the help! I was just hoping it wasn't something that was going to cost an outragous amount of money to repair.[/quote:2f7b422567]
Is the vehicle running at normal temp? or is it running cooler than normal?
If cooler than normal thermostat is most likely stuck open and needs to b replaced. That could also be the cause of the heat problem.
I would get a new radiator cap and try it first or have it pressure tested.
Feb 2, 2009 at 6:13 PM
TONYASUE98
It's running at about the same temp as it did before, but still blows out cold air. Sometimes it blows out cold air if the fluid is low, but lately even if it's just been filled it still blows out cold air.
Feb 2, 2009 at 6:35 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:194fe7bfa1="tonyasue98"]It's running at about the same temp as it did before, but still blows out cold air. Sometimes it blows out cold air if the fluid is low, but lately even if it's just been filled it still blows out cold air.[/quote:194fe7bfa1]
Ok, it could be the Heater Control Valve it is located under the dash board on passenger side first squeeze the glove box and pull it off by taking off the 3 bolts on the bottom then take off the 2 bolts on the heater core cover once that is off just look to your right there it is. Check all connections.
Feb 2, 2009 at 6:49 PM
