1994 Chevy Camaro ANTIFREEZE IN GAS TANK
1994 CHEVROLET CAMARO
27,500 MILES • 6 CYL • 2WD • MANUAL
MHAWS18
WELL I PISSED SOMEONE OFF AND I DONT KNOW WHO DID IT BUT THEY PUT ANTIFREEZE IN MY GAS TANK. I GOT LIKE 3 MILES AND MY CAR JUST DIED. I EMPTIED THE GAS TANK AND CHANGED THE FUE FILTER, WHAT SHOULD I DO NOW. IT IS STILL NOT STARTING.
Jun 2, 2009 at 12:28 AM
MMPRINCE4000
  • 8,548 POSTS
You will have to flush entire fuel system up to injectors. All lines , fuel rail, hard and soft lines.
You MAY have to change fuel pump.
Once everything is flushed check fuel pressure at rail with mechanical gauge. If low then change fuel pump.
Once system is clean, use starting fluid to try and get it started and flush any remaining coolant out of system.
Burning ANY coolant in combustion chamber will almost certainly ruin O2 sensor.
Once running buy a locking gas cap :) .
Jun 2, 2009 at 6:33 AM
